Details here: TDR Privileges
Going to install a FASS pump soon, not sure which one to get. Already have the intank pump, that the deale installed 100k ago. I might install some smaller injecters later this year and a newer turbo. Which FASS Pump should I go with? TIA... Scott
I have 02-3500 with mods. to 550HP. I am using FASS-FO-DO3-095G. It works great with pressure to spare. Call GENOS and ask for Scott,he will walk you thru it. The DDRP will not give you enough with your mods.
it looks as though they have changed model numbers around. Just want to make sure that I get the right pump, so i dint have to replace it as i build higher power levels, if i so choose.
