2nd Gen Non-Engine/Transmission fass pump
fass 95/150 what i need to know is the pump i have going south my psi is all over the place i know that when i put it on it worked great please help
:confused:
How's the truck running? Do you have an electrical gauge? If so I would go back over all the wired electrical connections to the gauge before doing any thing else just to eliminate that parameter. Be sure to check your grounds and power supply to the pump as well.
If that all checks out then I would investigate the pump, even go so far as to call FASS for some trouble shooting tips. Is your FASS one of the lifetime warannty units? Let us know what it turns out to be.
:confused:
