Yes that was the pusher pump the kit was complete and it runs good pressure 15+ and with the stock truck I have not been able to pull the pressure down past 16. I feel there could be some improvements made to the installation that would make this a even better product, as mentioned I will be trying to get a hold of DPP and visiting with them on it. It took a little longer to install than I had planned... might have been due to it being St. Pats Day and the green beeers. Started at 4pm took a dinner break around 7:30 and finished up by 11:30 pm.
Had to find tools remove pump and re-install pump find tools , find more tools, find beer, find tools ,find beer. find oil for hose. Bleed the air out , fired her up and check for leaks. If you have a lift to work on it would go alot faster. Getting to the fuel tank is a bit of fun in its self. Good luck if you go this route and if you do feel free to contact me before you do the install and I will be more than willing to visit with you on the phone about my install. I did run into one small problem when I went to purchase the system I wanted the 150 pump but was told that they were unavaible. So I had to settle for the 95 pump... ... . hopefully when I visit with DPP they will let me know something about getting a 150 if I still want it.
