Fass System
6 speed transmission, does it need friction modifier
Looking for info on the Haisley-McLeod street puller?
Are there any knew comments on the FASS system. I just ordered mine today and should have it next week. Whats the install procedure like.
Trey
Install is fairley simple, especilly if you have instructions, I did not . Attach the supply line to the top of the tank,run to fass pump and then to inj. pump. Run electric to old lift pump connection, attach return fuel line for fass pump to fuel tank vent hose comming off filler neck and you are about ready to go
Sounds simple enough, I too would like to go to the Fass system, but was wondering about longevity of the pump and if a failure was to occur while on the road where in the world would you get a replacement pump with out having to wait for the UPS truck in your Hotel room.
Thanks, TJ
