2nd Gen Non-Engine/Transmission fass
2nd Gen Non-Engine/Transmission fass pump
I don't know. I have used genuine FASS springs and also springs from Grainger's that I cut to get the desired pressure. I never had one break. As I posted on your other thread, check out the check ball behind the spring. It is soft plastic and might be damaged, causing pressure fluctuations and constant flexing of the spring, stressing it.
