Details here: TDR Privileges
I'm down to the last part on installation and On the supply hose at the tank. When you put the new hose on the tube do you have to remove the plastic clip on the old fitting or do you just slid the new connection over it? Thanks
The factory clips on the quick disconnect has to be removed. Gently pull and twist a little on the clip and it will come off. Check all your fittings to make sure they are tight and I would HIGHLY recommend Permatex #2.
