Fast Idle Revisited
more power+foot control=more mpg....whats your mpg
website update
Is there any thing on the market to create a fast idle while parked?I know there is for the 24v,i need the 12v. We have air compressors on our trucks at work and need the idle to kick-up to 1200rpm when the compressor engages. Need help a. s. a. p. Thanks.
Mike,
Yes nothing fancy. Basically a cable(I believe old fashion choke cable)that hooks to throttle linkage and routed to inside of cab. Bracket hooked to bottom of dash.
I think this would be best solution for your problem.
Try the archives if you need more ideas. If nothing comes up change your wording.
In the mean time I will try to remember who has this type of set up.
Bill Thomas
Missouri Mule - 96 Wht 4X4 ST CC,5 spd, 3. 54, 8 ft bed, 1 ft high cheater boards.
99 Freightliner bl/wht FL60 ISB-5. 9 24v,215 hp,520 tq,6 spd, 3. 59 nsr,16 ft box, 19. 5 tires,Wt/gvw 11,000/23000
The only problem with the cable is that every time the throttle is pushed down, the ridged cable flexes and eventually brakes like a twig wiggeling it back and forth.
We have set up a few. We found the trick is to get the linkage to move freely when the throttle is press not moveing your cable. ie drill a hole in the linkage and put your rigid cable thru, then put somthing on the end of the cable to catch the hole when the throttle up cable is pulled. When you are drinving the factory linkage doesn't even move your added cable.
2000 2500 long box 6 speed with everything but cab roof lights,Pyro, Boost, K&N, 4" exhaust, BD Brake, OEM nerf bars (best fit), 1 877 511-5599
I have a manual throttle on the wrecker that I drive and It has a piece of steel beaded chain connected to the end of the throttle wire and the actual truck throttle linkage. Also I've seen light guage flexible steel leader used the same way. Hope this helps. One more thing, Our firetrucks at work as well as the ambulances use electric solenoid controlled throttles to automatically idle the truck up when the amperage usage goes up. They all have cummins diesels, 12 and 24 valvers!
1998 12 valve slightly modified 2500 4x4 quad cab. Large diameter straight exhaust, wife got mad and took the cat! Conexed grant XL with little ol' 200 Palomar, Wilson 5000 mounted high (and permanent!)
I do alot of offroad driving and I've several guys use bicycle thumb shifters. The cables are adjustable and the control can be tightened to hold idle. You can control engine speed with your thumb while your feet can run the brake and clutch on tricky hills and when loosened up it doesn't interfere. I'm not sure if it will as good on a diesel, the throttle pull on the jeeps is pretty lite.
93 W250 5spd Getrag, 16cm2 housing, Bank exhaust, K&N air filter, pyro and boost gauges and moderate pump adjustments. Daily driver and love towing anything.
I know it's kind of a backwoods solution, but here is what I've been doing until I get something else set up. I take a chewing tobacco can and slide it behind the top of the throttle where the cable hooks. You can slide it down and adjust your idle wherever you want it. The only downside to this is reaching under the dash with the door open everytime you want to engage or disengage.
'95 2500 Ext. Cab, 2wd 3. 54 limited slip, auto, TST 230/605 plate, TST low stall T. C. , K&N air filter.
Mike,
I put a fast idle solenoid on my 97
Dodge Cummins, activated by toggle switch
on dash. works good, and is adjustable
for rpm desired
Harold Bowers 97 4/4 5 spd. 3. 54 gauges,TST power kit,BD ex. brake, love that Cummins
Thanks Harold and others that have replied. Harold where did you get the solonoid,and what did you use for brackets?Pics of this would be great.
Mike,
I'm fairly new on this computer,
so if you want to email me I'll
be glad to respond, and see if I
can send a picture. just click on
little envelope across from my
name, to get my email address.
I've got a an automatic idler for my 12v from Diesel Solutions or something like that with the company out of Canada. I love it and use it all the time.
It has a button that activates it and a switch that sets the rpm, works great. I would highly recomend it.
DD
95,000Miles!
Yes 'mam it is a rolling office/bedroom/pickup/stinkpot/the best truck ever made!
1998. 4 4x4 Quad Cab 2500. 285/75/16 White w/gray trim. TST#8 plate. Limo tint ALL Windows, Whistler hidden radar built into overhead dash, Combo toolbox/41gal tank, electric start, Car Alarm, Lund Grill Covers, Electronic Idler, scotty's air intake, K&N Prefilter, Hadley Bulley Air Horns Mounted Bumper Level, Banks Pyro and Boost Gauge on the A-Pillar, and more to come.
Mike
I obtained a throttle cable kit recommended by other TDR members from AW Direct that caters to tow truck drivers needs. It does not interfere w/ the actual throttle linkage & the cable is solid wire strands inside plastic sheath w/ a solid wire going thru doing the actuating. Very stout, works well. Different cable styles available also: i. e. turn pull & lock, turn knob push button release etc.
http://www.awdirect.com/
Mike
