Engine/Transmission (1998.5 - 2002) Fastest 24v w/4.10?
2nd Gen Non-Engine/Transmission PCM/Cruise Control
Engine/Transmission (1998.5 - 2002) Warning
It seems like I always read that the trucks equipped with a 4. 10 do not do as well on 1/4 mile times. I thought with a 4. 10 you can get out of the hole quicker resulting in a better 1/4 time. Please feel me in for I am still learning.
Mine ran a 15. 3 @ 93 with the mods in my sig and a bad vp. Due to my injuries I use hand controls to drive, and the way they work I could not build boost off the line.
I ran a 14. 2 when I still had the 275rv injectors and had 4. 10 gears. I recently swapped a 3. 55 into the rear but haven't been back to the track plus I have the Mach 4's now so it wouldn't be a fair comparison.
I too am curious on this. . I have not been to the track yet nor on the dyno, but curious to see where I'm at with my mods. The truck seems pretty quick off the line :D
The first variable you need to consider, is do the mods on your truck require you to go faster in the 1/4 mile than your truck will max out at with 4. 10 gears. and That is one of the only variables you need to consider
