i got a fault code 12 and 24. in the book the 24 code has ** beside it which indicates that it should be giving me a "check engine" lite when the engine is running. it doesn't. the fault code 24 is the tps voltage too hi/low or doesn't agree with the map. i've checked the voltages on the tps. they are fine and smooth.
is map the manifold air pressure sensor? has anyone had to replace it?
my tps is only 25k miles old.
still searching for my problem. it is acting just like the tps when it went bad.
thanks for any input. scott.
