Drag racing 101
100 lbs worth about 1/10 is close to being correct,,As for the gate and tonneau deal,remember these trucks were designed to be as slippery as they can with the gate up and no cover,,So as far as an advantage for wind slickness for speed,it will not make a major impact,,Now for weight thats different there will be some impact,,Steve,you say you could not run numbers in summer months comparable to earlier,thats easy to figure out,one easy answer... WEATHER CONDITIONS... ,,Did you tune with a weather station??,,Look at the difference from early to late and also consider track conditions,slick,asphalt or concrete launching pads,bald spots and "marbles"(small rolled up rubber at line) will also play a major part in your all over numbers,,One last thing from a racer,easy way to consistent et's is be dead on the tree and leave the same way all the time,,Routine is the best way,into water box,light spin for water,ease up fry the hides well and spin them all the way to line,stop short clean her out,stage and go,,One thing that kills et is the dreaded dry hop after the burnout,it removes any heat you have just put in and will hurt the inital hook,since you already did it by dry hopping,such a novice mistake,,Now this is really the end,feeling windy tonite,an easy way for lower et's,well maybe not so easy,is by reducing your rotating weight,,1 lb is worth 7 hp,lighter wheels and tires,aluminum or titanium driveline parts,better axles, spools and so on will definately help,,Cost here is the issue,,Got my driveshaft person working on a set for mine for next year,not sure how the torque in our trucks will affect it,but,one never knows till he tries... ...
