The Cattle operation is growing with the acquisition of a few thousand acres of land and very possibly few thousand more. This will mean the setting of fence posts for a 3 wire run of Barbed wire around most of its boundaries. I hope that you folks can help me out again like you did with the post hole digger on the tractor that is still boring holes in the ground.
I have had nightmares about using the old manual method of post driving, I don't think that my arms and shoulders could do that very long. We are unable to get to some of the property with any sort of tractors or large machinery. So I have been looking around and found this, I like the Honda motor and it can be used to drive a lot of different type posts. There will be a need for control gates so a larger pole on each side of the gate will be necessary, this can drive most all up to I think 2 1/2 inch. Also a pole every so often will be needed to pull the wire taught then a larger pole will be needed for that. The main pole driven will be the T type fence post.
http://rhinotool.com/products/post-drivers/gpd-45-multi-pro-gas-powered-driver/
If anyone has used or seen any other product that maybe something for us to look at please feel free to link it our way.
Thanks for your help
BIG
BIG
