Originally posted by Crunch
Looked at it. Don't like it. I mean it looks like a Tonka, but it probably drives and lasts like a Ford. You can also see the desperation in that truck as they try to copy the Dodge curves and lines.
This was interesting, though:
"The HLA system, currently under research, is designed to improve fuel economy in large trucks by an estimated 25 to 35 percent in city driving. It A reversible pump/motor attached to the driveshaft through a clutch system and an energy storage module work in tandem with the traditional powertrain. The HLA system recovers energy normally lost during vehicle deceleration, stores it in the form of hydraulic pressure and then reuses it during acceleration. "
Let's see... If you are getting the PSD standard of 10 in the city and you up it by the HLA max of 35% you are getting 13. 5MPG in the city. About what a Dodge gets on the highway pulling a fully loaded trailer.
I also think I've seen toilets with a bladder in the tank that work in a similar way to make up for the low volume flushing...
