figuring out hp based on 1/8 mile et and mph.
Texaco MTX Fluid for 6-Speeds
need 4 gauges, need gauge pod opinions
LPG???
Your a brave man Jim, running that Lpg on the ETH. How do you like it ? Just curious, sorry I don't have an answer for your post.
Scott W.
the propane works good. although i have blown a head gasket, like others. so far i don't know of anyone blowing another head gasket. so maybe there was a problem from the factory with certain head gaskets. i only run the propane while on the dyno and racing.
how much boost do you run with your eth? with your 3's and your 5's?
jim
I see 45 with the 5's, real easy to get there also. With the 3's, normal driving brought it up to 35-38 psi's, hard acceleration in 5th or 6th would see somewhat over 40 psi's. Turbo is wastegated at 45 psi's. Thanks for the info on the lpg.
Scott W.
