Details here: TDR Privileges
It's there to keep the fuel from running out on the ground in the event the truck rolls over. Why would you want to remove it... you can "overfuel" the truck at the big rig pumps at a flow rate high enough to damage the fuel tank sending unit with it in place.
That's what I was looking for. I had the filler neck off putting on a connection for my auxilary fuel tank and was just wondering. I am not going to remove it.
If your auxiliary tank is in the bed and you leave the valve open, you need the check ball to keep fuel from running out the filler neck. There are openings in the neck between the top flapper and the lower ball seal.
