Details here: TDR Privileges
I believe someone did mount the filter minder in a 3-inch schedule 40 coupling. They drilled a hole and used the rubber grommet for mounting (just like stock).
I remember seeing a picture posted but don’t have the link
About a 6" piece of 4" ABS pipe. Drill a ¾" hole in it (centered) That will fit the stock gromet for the minder. The stock turbo hose will go right over the 4" ABS. On the other end I used a clay pipe coupling. 4" to 4" it's rubber lined and has a metal wrap with 2 straps. People were using the 3" coupler inside the BHAF opening to stiffen it up. I haven't had the need with my set up.
