Is it really dirty?
What we see and call dirty (filter) and what negatively effects the engine are not the same thing. Many of us after turning up the power found we could move the Filter minder. Some can even move the minder with a new filter with a stock airbox and snorkle inplace. No dirty filter there.
On the other hand I had 70k on an Amsoil filter that I NEVER open the air box in 70K miles. Rather then service I just replaced with new. Had several oil samples telling me that it was still doing its job. Filter minder did not move so I knew it was not restricting flow (I can pull the filter minder down with a paper filter). When I removed this filter it was caked with a dust,oil,bug, crud that you could have measure the thickness over the entire surface. Visually, it would have been service or replace at 20 or 30K. In reality it was still working fine at 70K.
I think in many cases, air filters get throw or serviced way before their time. The filter minder will move of the filter is truely causing a restriction! Busting snow banks will cause even a stock truck to move the minder.
Most filters, filter better as they get some buildup.
The filter minder will tell you if if could be hurting power!
Oil analysis will tell you it is still keeping things clean.
Keep the airbox close and just watch the Minder!
jjw
ND
