Filter questions.
2021 safety recall
Diesel Exhaust Fluid ??
Hello. I'm new to the 4th Gen forum. I sold my 2002 3500 Duelly and bought a 2019 Longhorn, Duelly. My question is, I have always used Donaldson filters and would like to know which filters and what are the codes for oil, fuel and air filters. Thank you in advance.
Ram and bought a 2019 Lomghorn. My question is, I have always used Donaldson or Fleet
As mentioned the DBL7349 is the oil filter of choice.
I stick with OEM air and oil filters as well. I’ve done a lot of research on filters and OEM has air and fuel filtration figured out.
Thanks guys, for the info on oil filters. Is there a preference and and code number for air and fuel filters as well? Thanks again.
Go to Geno's Garage and you will have a choice of MOPAR, FleetGuard and RACOR filters. I don't think RACOR has a fuel filter for the 19-22's ???
It doesn't appear so. Either my memory is failing me or we had hashed this out once before when the 19's first came out. Someone posted up some #'s on the cartridge housing and we verified that it was indeed a Parker Racor housing.
But it is strange that they are not being offered as an alternative like the 13-18 spin on's.
Thank you all, but I live in Canada and would prefer buying my filters from the local filter supply house that I have been dealing with for years. Geno's really isn't an option for me as they are available here if I only had the codes for fuel and air filters. I already have the filter numbers for oil, and thank you all for your help. Any chance of getting the fuel and filter numbers for fleetguard ? Thanks
Thank you for your help. I now have all the numbers and product names.
KT, just as important as the filters, the '19+ trucks need different oil. Do not use 15w-40. Recommended is 10w-30 synthetic blend or 5w-40 synthetic, depending on your climate.
Hello. I'm new to the 4th Gen forum. I sold my 2002 3500 Duelly and bought a 2019 Longhorn, Duelly. My question is, I have always used Donaldson filters and would like to know which filters and what are the codes for oil, fuel and air filters. Thank you in advance. Ram and bought a 2019 Lomghorn. My question is, I have always used Donaldson or Fleet
I found this Donaldson website with applications BUT I didn't see 2019 listings. It might give you a lead on your search.
https://shop.donaldson.com/store/en...898+2184523821+91324302+2475381917+3181234242
Use your owner's manual to get the Mopar oil filter part number, then Google it to get cross reference to other maker's products with part numbers.
Cheers, Ron
Keep in mind your local supplier may not have the primary fuel filter if they are a Fleetguard vendor. It appears that the Mopar #FS68436631aa and Baldwin PF46152 are the only available filter choice. Wix shows one but not available. Be careful of Amazon, they show a bunch of junk.
If I had a 19 up it would be running the AMZ/OIL full synthetic 10-30 as there is not a hill of beans difference in cold temp performance with the 5-40.
