Filters...
New gauges and rear diff temperature
DTC Code Reader
OK, I just ran my last Mopar-badged Fleetguard filter. Going to need a filter for tomorrow's oil change.
I have ran Purolator in the past (over 200k on my 99 on 5k filter change intervals), but the local store has Wix filters... both are good names, anyone see any reason I shouldn't be able to run either one 20k??
Personally, I would go with Wix before Purolator. Or get Fleetgaurd filters. Most likely Wix, Baldwin or Fleetgaurd make most of these filters for each other anyway.
I am guessing you are running a bypass setup to get to 20K? Again, personal preference, but I will not use an oil filter past 5K. Too many heat cycles through the media for my tastes. I will go 10K on fuel however.
Dave
I've got over 20k on the filter on the truck now, and this isn't the first... I look at the fact big trucks run long intervals on filters, its the same media.
Yes, I've got a bypass...
Well, looks like I'll go pick up a Wix later today... I can also order them by the case.
Dave
Dave: Based on your sig it looks like you're in the diesel/retail business. I've always been curious about the life cycle of oil filters in on-road engines. In the marine world we run them in our medium and high speed engines on average 500 hours. The main difference is that these engines are driving generators, 100% duty, running at constant speed with various loads. I checked the hours on my truck engine last year @ about 20,000 miles and came up with about 500 hours. I'll assume that Cummins did extensive research and was confident allowing the (Schedule A) 15,000 oil and filter change interval on the 5. 9 HPCR engine, with plenty of wiggle room. I will also assume that the synthetic Stratopore media is essential to that extended interval. The 6. 7's with EGR have had their intervals sharply reduced. I've had mechaics tell me that oil filters actually filter better after they have been in service for a while. In the end, it looks like the interval should be based on the truck you have and how you drive. I've been changing my oil/filter and fuel filter at 10K, nice round number. Further thoughts from TDR members will be appreciated.
If you use an Amsoil Nano-fiber oil filter, they (AMSOIL) recommend a filter change up to 25,000 miles/one year, whichever comes first, when used with Amsoil oils.
Their recommendation for the DONALDSON "Endurance" brand filters used in Commercial vehicles and off-road applications, when used with the Amsoil oils, is up to two times longer than OEM recommendations, not to exceed 60,000 miles for on-highway Diesel applications. They also recommend changing oil filter at the time of oil change.
This info is listed on their web site.
Most CASE IH dealers carry CASE IH Ultra branded fleetguard filters for the 5. 9 ltr cummins or the fleetguard stratapore itself.
I went with a Wix for the time being... I can change back to Fleetguard during the next filter change if I feel its needed.
I just order my filters from Genos and get it over with. Their prices and service has been great and you get the fleetguard stuff.
I don't have any first had experience with marine applications other than small Hinos on the old 3288. But the way I see it, the marine engines typically put more hours at a given time on at once. Not that matters, but with marine applications running at a constant load/ speed and the varying loads seen by the light duty trucks makes me wonder.
In our old race car program we could clearly see the immediate effects of trying to stretch out filter changes. While a dirty filter technically filters better due to the media becoming loaded, at some point, flow is compromised. Most engines have a bypass built in to avoid oil starvation. When this circuit is active, filtering virtually stops.
Also, when cutting open filter elements on our tow vehicles that spent thousands of miles at a constant 60mph, the filters were much cleaner than the trucks that had many stop and go trips.
We have had filters fail, and one of the causes we are sure is heat cycles. The media had lower miles, but almost all in town driving. Lot's of stop and go. It just beats the filter to death. Heat and cool cycles damage more than it's share of other parts. I don't think it's a stretch to assume oil filters are subject to similar conditions.
I remember I found a '68 GTO in an Arizona barn as a kid. When I went to get it running, the filter was just nasty. Apparently, just sitting with nothing flowing through it was damaging to the filter.
What does all this mean? I would follow the manufacturers recommended guidelines for filter and fluid changes. I would do them more often as power is turned up, or more extreme use is encountered.
So, I just err on the side of caution.
Dave
