I've got some questions about the stock D70 rear I have:
•I'm looking for about 500-550 HP and screw around a lot... am I going to kill my D70? Should I look into a D80 conversion? I'll be running 315 (~35") tires.
•If I can continue to safely run my D70, what is the lowest gear I can run in it without changing carriers if I currently have 3. 55's? (I'm thinking of 3. 73).
•How tough are the stock u-joints? Should I look into converting to the next size up?
•Also, I've been crunching numbers and found that the 3. 73 makes the truck run like 3. 55 with 33" tires (keep in mind that I have a slushbox)... do you guys think that's a good final drive ratio? Or should I look into just getting 4. 10's? 3. 90's make the truck run close to stock when running 3. 15's... . but I haven't found any for the D70 or D80???
Thanks guys!
Thanks guys!
