2nd Gen Non-Engine/Transmission Final review of the Smarty and 2nd gen auto
Jusy a partial review of my personal experiences with the Smarty.
The truck setup then was 3. 54 gears, 265 tires Mach 3's, EZ and a DTT auto. I sold the EZ and switched to Comp. This setup worked pretty good with my only complaint being the reliability of the Comp boxes. It was in this timeframe I had heard all the rage of the Catcher (that's the old school ECM to those that never had that pleasure) and Bob gave me a loaner to try out. I liked the throttle response, the ability to smoke at will and the reduction in timing noise. But, I stuck with the Comp for some time.
Eventually, I went to Mach 4s. Cleaner than the older technology Mach 3s, better milage andd less smoke. Sign me up! I still ran the same electronics, but again, was plagued with faulty electronics. I decided to make a switch.
I bought the Catcher before the release of the Smarty. I was told they were not near production, but I had no idea they would be released so soon afterwards. With the Smarty, the marketing was simple. The ability to have different tuning in the same box. The ability to go back to stock, or change power levels while reading codes and correcting tire change heights. Sounded like the ultimate in adjustability. Since the Mach 4s were proving to be more of a handful than the milder Mach 3s with the Catcher, I thought this might be the thing that does it!
So, on goes the Smarty with a reflashed used TST. The Catcher is still in my drawer as a backup ECM. Everything ran pretty good. With the small turbo and the tight auto, it was driveable. No real issues other than the useless cruise on the Catcher levels. I didn't have the stacked shifts, but the speed to hit lockup had increased. I would hit lockup around 45mph. I was having the surge issue, but after being told it was only my truck, I just lived with it. Later, I found out it affected many trucks and there was a software change. Thanks Marco!
As I wanted some additional cool air, I added twins. There was no driveability change with the Smarty other than I could now have the fuel come in earlier without as much smoke. Cruise control was completely out of the question at any speed if over level 3. I figured I had a sensor issue and tried to track it down. After replacing marginal IAT, MAP and eventually VP44 and cam sensor, the problems in the software remained. I had thought there eventually would be a fix so I lived with it.
Later, I went to a bigger injector as I now had the air to run it. Truck spooled very fast. Especially with the Smarty on level 5. Definitely put a grin on my face. Then I tried to use the cruise. It would build boost, accerate to speed and the throttle would lift, dumping the boost. Then it would tip back in smoking out traffic. At higher speeds, the smoke surge was not as bad, but you felt like you were on the high seas. Accel, decel, accel, decel.....
The lockup point moved even higher still. I tried raising the APPS voltage to the limits of the ECM to accept it with only a small reduction of lockup speed. This is still a pain today. I have also experienced some stacked shifts around the 30 mph mark. I am guessing all the issues I have had relate to throttle position vs fueling alone. Since the trans gets some input from the PCM as well as a physical link of the cable, it only makes sense that the Smarty can affect the transmission indirectly and directly. Also, the smoke level is very high with the larger injectors and any conditions that would add lag. Heavy loads, big turbos, warm weather, ect.
We had all been patiently waiting some updated software to deal with these issues some of us have been having. If it's the same handful of people like in the original surge issue, then it affects every auto out there. It's just not noticed by everyone. I have endorsed the Smarty as I felt that we had finally had a program that was stable and reliable. Also, I felt that the designer absolutely cared about the issues we were having and was working hard on a fix. I hope that's still the case, but I don't know.
With testing with the Edge products recently, I was pleasantly surprised all the negative issues were gone. Of course, you now have the torque management system back in place, but the truck is much more fun to drive and you don't get seasick if you are driving a rough road and the pedal is getting some play.
I have loaded the Smarty level 3 back into the truck and plan to look for a EZ. I have put the Smarty under a seat in my boat so it's there when I go fishing and I can use it for the anti theft software. I'll leave it there until a revision comes, if ever. Since no one will say if they are or are not working on it, I won't hold my breath. And since I can always get another Edge product on warranty, that seems to be the move to make.
I still think the Smarty platform works. And for 90% of the guys, there won't be any issues. There will be, however some issues for some guys. I will be a Smarty fan again if the program ever gets changed. It pains me to lose something that has been so stable. Just like the TST!
If you have a modified automatic truck, take careful consideration of using the Smarty program. Especially if you have mods that were not designed into the original Smarty/ Catcher format. It took time to see the issues.
Sorry for the long post. But I can no longer support a vendor that does not support us. If things change, I'll be back!
Dave
The surging with Cruise is fixed with a WD40 straw in the cruise Vac. line. I have been running my Smarty on #9 since day one. :)
Smarty&2nd. gen.
Other than the need to roll into the throttle in order to not blow out the guy behind me on #9,I enjoyed my Smarty loaner immensely. Cruise worked perfectly and shift points were unchanged with my DTT. The impending sale of my '99 kept me from buying one. The Edge J/A is supposed to be an awesome product now for the 2nds so that would certainly be a desirable product. You've certainly tried and tested multiple products out there. Thanks for the comments.
Seems there is a point of BOMBing above a certain level that increases problems with the Smarty (don't have experience with any other products).
Can anyone pinpoint that treshold?
Seems there are products like Juice/ATT, TST, etc that push Smarty technology past the limits of daily drivers.
Lite to mild injectors/low power timing box/stock turbo/etc seem to work OK almost all the time?
Bigger stuff seems to increase the probability you run into problems.
I've been happy with my Smarty w/only DDII injectors, VA box, DTT transmission, and AirBulldog hood with the exception of the cruise control even with the WD-40 fix (and a slightly modified one at that... cc is unuseable other than towing my trailer).
great post fish ,i love my smarty too and also put up with its short comings with the auto & cruise, but i really dont see them( i bluntly asked) updating 2nd gen software as (lets face it )the market is in decline as compared to the cr. someday maybe i can get a newer truck and the importance to performance companies that comes with it. i love this truck and will have it (god willing) for some time. bombs are slowing as hype gives way to time proven fact ... um k&N. . 1st genners have a set formula 2nds are almost there, and so on at least weve found the "bugs" and can decide or not to use it as is.
Only thing I noticed about some of the above comments regarding the WD40 fix in the vac line for the cruise is the original post was about an '02. The '01-02 trucks have electronic cruise.
I was thinking the same thing about the different yrs... but my 98. 5 is improved only slightly with the fix and barely usable when I tow with the wt of my trailer (maybe three times a yr). It's not so much that the surging is annoying but you know it can't help fuel mileage.
i know of a few 02's with vac CC. my truck locks up at 45mph and has that anoying cruise issue as well. i have the ottomind set for the power pack on my truck.
By no means am I saying this affects everyone. These are just my personal experiences.
I have gotten a response on another thread from Marco. I am willing to try to work to a resolution instead of making this thing a paper weight.
There is a declining market of VP stuff as has been stated. But many of the VP owners have and plan to keep those trucks for some time. So, while there is not a surge market, there is always someone looking for a top notch product.
So, our experiences with the VP could be considered when it's time to BOMB the new truck.
I am hopeful these issues will get resolved!
Dave
I have a late build 02 with vacuum cruise and have the straw in it and it did absolutely nothing to help surge. Cruise is useless to me also with smarty. Stacked shifting is also horible. But the smarty still makes everyone smile when they feel what it does.
I have not gone far enough to get a real good feel of the differences.
Tonight I have some mixed city and hiway driving and should be able to get a better idea of whats going on.
I am also going to get some test leads mounted under the hood so I can get a picture of what the PCm is telling the trans and what voltage it is seeing from the APPS.
Simply by softening up the bottom, I think the issues will get resolved. This may require some additional torque management on the bottom or maybe no Smart effect until a deeper throttle. We'll see!
I am not a software designer or a techie for that matter. So, Marco is gonna have to take my seat of the pants descriptions and try to turn them into 1s and 0s. :cool:
Dave
Dave
Dave Dave;
I think I softer Smarty bottom end might fit more than you auto guys. A little more spool before the smoke blows might be nice for guys like me also.
Thanks for your effort;
Jim
I agree with Jim on this. I too would like a softer bottom so I can drive on some of these washboard roads around here without having to turn the Smarty off. Some of the worst sections of road I can't drive at all unless I'm at idle with any of the Catcher programs loaded.
Dan
Good News???
I have a 99 and complained of these problems some time ago. I know Marco was working on the CR stuff so no response. To me the smarty is only usable on level 2. It's the least sensitive and allows me to use my Edge Comp. I'm not sure why the throttle has to be this sensitive, but that's just me. Cruise is barely useable without the camper on the truck, but I still have to use it when on a piece of rough road as the poor engine is all over the place. I sometimes turn on the Comp to 1X1 to keep smoke all the way down. This still gives me all the power of the smarty, but much more user and follower friendly. I would truely love to have a smarty setting to approximate something even close to this. If I use the smarty on 8 or 9 it's almost undrivably sensitive. Throttle is an on/off switch. Yuck!
Please let us know what you think Dave. Maybe he will offer something else as an option.
Dennis
Dave
How did the tests go with the new program? I am impatiently waiting for some good news here for some improvement cudos. Oo.
As are many others :cool: Oo.
