Yo Hoot
I was getting an occasional loud pop or snap like something was letting loose in the front end. Usually happened in a tight slow turn and hitting the brakes. Also hitting the brakes suddenly sometimes caused it, forward or reverse. That's what made me start thinking it was ready for a once over with the wrenches.
Seemed worse with the plow on.
Yesterday I took a hand full of wrenches and a 1/2" breaker bar and a 13/16" socket and went to town on the front end bolts.
The top bolts on the links were pretty easy to tighten. These are the factory torqued bolts that attach the control arm links to the axle.
I tighted the upper and lower bolts, at the axle and at the frame, both sides (8) total.
Also my plow brackets needed a good bit of tightening after a few snows.
I did get the popping before I installed the plow and at times when the plow wasn't on.
I'm plowing tonight... ... no popping at all.
Previously I tightened the track bar at both ends but that didn't fix it.
If I hear it again I'll report back.
