Finally!!!
Cold Start Temps
Anyone w/ a 6" BullyDog Exhaust Yet?
Finally got my TST PMCR installed again today. All I can say is WOW!!!!! Unbelievable!!! Why did I wait so long!!!??!?!??!!?? Oo. Oo. Oo.
The highest I have run it so far is 5/3. It's got soooo much more power now. I need to upgrade the air intake and turbo before I go any higher than that. I have the money for the clutch already but don't want to spend it yet.
skip the FE and go to a dd street aplication from southbend, I have a TST and EZ stacked and I went through a FE in two weeks.
Above too forgot to mention with a 3rd Gen and a dual disk you will need to upgrade the clutch slave cylinder to a 12V setup.
Justin found out the hard way! :p :-laf
I'm running stacked with the C3. 1 and even on 7x7 and 100% pressure I haven't had a problem with my OFE. I must be lucky!
Richard
Like I said. I must be real lucky. I just got back from a 2300 mile tow grossing 18,000 and towing on levels 3 and 4 with zero problems. I must say that I don't try hard launches, drag or pull with this truck. Just heavy hauling and general play so I don't test the clutches abilities like you hard runners do. Man, I must be getting old. :-laf :-laf :-laf
Richard
