Fire in engine compartment......!
Stacks
Engine timing pin
I ran across this link today, it's an ISB Ram with engine compartment damage due to a fire aparently,but i'm wondering how, but maybe you guys would be interested in buying it... go check it out: www.casmiami.com/autoseek/dodge/611367.htm
Greg's 1993 D250 4x2. . 5-speed. . extended cab. . longbed. . bright white. . tinted windows. . 4-inch stack through bed. . K&N air filter. . holes in air box. . Piers' "tweak inductioned fuel pump"... . PW injectors... 12CM housing... Isspro Pyro &Boost guages. . "The{smoking}Phantom"
no expert but looks like the fire started on the passenger side around the exhaust area...
TAZ... 2001 2500 SLT+ 4X4 Auto ETC Cummins, LSD 3. 54,Quad Cab, Long Bed, Agate Leather, White/Driftwood Exterior, Sliding rear window, Camper Special Group, Towing Group, Cab clearance lights,SPA-Technique Digital Dual Gauges (Pyro/Boost, Trans pressure/temp) Aux. Backup lamps. BNM 5th Wheel Hitch, Additional Body Molding on Bed. Line-X bed-liner. DTT's TC & VB, Pac Brake, Power Edge, Edge EZ, Grover Air Horns
2000 32' Aljo Triple Slide 5th Wheel.
http://www.ramtaz.com
Add on's to come: any other Ram Runner required modifications...
I'd bet good money that there's bearing damage or some other terminal internal damage to the Cummins... I bought an engine out of a wrecked vehicle once, thinking it had to be a good engine... . keep your eyes open and your thinking caps on... ...
2001. 5 intenseblue ETH/DEE 4WD QC sportpkg, all the options but the cowhide, mostly stock. NRA, AMA member
