I'm about to do my 1st retorque after installing fire rings and 12mm studs from Haisley's. My question is if I DIDN'T use the supplied lube with the studs, did I get the torque on the nuts my wrench was reading at the time? I didn't.
I have coolant leaking out from the head area but I only get to 20 pounds of boost with my new Piers HX-40?
I couldn't have blown a HG at 20 psi? Could I??
I was wondering if the mild steel fire rings, which would require a bit more clamp to compress because the mild steel is so resistant( like spring steel) would necessitate the use of the stud lube for MORE clamping force on the head.
