Engine/Transmission (1994 - 1998) fire ringing and o-ringing a head
Engine/Transmission (1994 - 1998) Radiator/coolint making noise
Engine/Transmission (1998.5 - 2002) 300hp bosch injectors
whats the difference between fire ringing and 0-ring-ing a head ,,, and whats the pros and cons,,, and any other info the trd memebers would have ,,, thanks tony
fire rings sit on the block and o-ring is used with the stock head gsk.
fire rings will hold 70psi or more and o-rings will hold up to 70psi, but I have o-rings right now and running about 65 maybe 70 lbs of boost and still have head gsk problems.
Sorry forgot to tell,
97 2500,twin turbos,370 inj,4000 rpm springs,custom plate,water meth injection,5'' exhaust,high ark intake,o-ring head,13'' clutch.
