fire wall
transmission shudder at lockup
Help! Dodge Cummins in boat
Hi Ya'll:
In looking at the fire wall, getting ready for gauges, I don't see the correct place to penetrate for the pyro. and boost line. The only spot I see is at the wires,(power) and that seems low for the boost line. A friend said this was a 2 hour job, I can't seem to get started... ... ... ..... HELP... ... ... .....
Preston
96 3500, Black SLT, 5 speed, turbo diesel, , with US Gear overdrive, Rhino liner, Reese 15,000 lb. fifth wheel hitch, US Gear de-celarator exhaust brake, muffler elimination kit, Amsoil lub. , Mag-hytec rear cover, dual-remote by-pass filters, and Roadmaster Active system
Yep, the "big grommet" is the place. Remove the knee bolster if you need to, so you can see the inside where the grommet is. You can use a coat hanger and after punching a small hole in it, thread the wire or line from under the hood. Then you can reseal with black RTV sealer.
Thasnks Doc.
Here I go.
Preston
And if that doesn't work,use a drill bit and RTV sealer on the hole. You will have to drill into the truck sometime!
Good luck.
Phil
`01 2500,4x4,QC,LB,ETC,DDX,DHG
3. 55 LSD,Tow Pkg. ,Snow plow pkg. ,Forest Green PC,Mopar alum. side steps,Mopar mud flaps with Cummins logo,Mist grey seat covers,Tekonsha brake controller,Hadley air horns,Pacbrake.
Built in St. Louis
THE BIG GREEN MACHINE
Phil Stuart
And still another... .
I enlarged the grommet opening which allows for the hood release cable. This was the Jacob's E-Brake installation manual's recommendation.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, HO Cummins (ETH), 6-Speed (DEE), SLT+, 3. 54 LSD, Camper Special, Trailer Tow, Heated Leather, Sliding Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine + diff. temp. ), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec, Mopar Tow Hooks, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper. "Do it in a Dually"
