I started the install on my bags last night. The sales write up was "easy, no drill" etc. No big probs so far but far from straight forward. My kit goes on the inside of frame. Hade to remove the e-brake axle clamp and grind to different shape and move cable. Next was working around the brake proportiong valve. I took lever arm off and bent away from the bag. Also ground down the arm for clearance. The actual bracket that mounts to the frame also had to be ground quite a bit to fit nicely against the truck frame on the bottom. Question is, how important is the proportiong valve? Instructions came with a TSB about removing it and running a direct brake line. Seems that this applies only to some 97 and 98 models. Anyone familiar with this issue feel free to advise. I am not against removing the valve altogether, just thought it would be useful at times.
