Has anyone installed the no-drill Firestone Ride Rite air bags on an '03 3500 DRW LB rear axle? The Ride Rites fit on the rear axle inboard of the spring pack and fit on the frame using the frame to axle rubber bump stop bolts as the air bag bracket mounting point.
I currently am using Air Lift 5000s on my '00 3500, but they won't fit the '03s. The Air Lifts for the '03s require drilling the frame.
Also does anyone know if the Air Lift lines will interchange with the Ride Rites? I am using the Air Lift on board compressor and gauges and would like to continue using them if the plastic lines with the push-on connectors will interchange.
Bill
Bill
