I was invited to go with a friend to the FordDeiesl.com dyno run up in PA. I Just went to watch. 4 of the ten trucks scheduled for the dyno didn't show so they let me run my truck. Three runs 408. 9 410. 4 409. ? I kept blowing the exhaust hose in two pieces. The runs were done all in 4 gear with a rolling start at around 40mph. Top speed in 4 as measured by the dyno was 109mph. They couldn't hook up to the tach to get the torque reading. If any of you number crunchers know how to figure it out please do so and post it. 17% driveline loss gives me 480. 17 at the flywheel. 410. 4hp at 2550 rpm at 75mph in 4 with 36" tires and a 3:54 gears. I know the speedo is off with the tires but we got the rpm at 75 using David's GPS system on the way home. I also couldn't get full boost on the dyno. I only boosted to 37-38lbs when on the street I go to 45-46lbs on a good hard pull. Thanks for the help.
Tom
I had a great time with the ford guys. There was no brand bashing and I have made some new friends. We are all working for better perfomance for our diesel engines. Look at their site and try to go to one of there events. They are great people and very helpful.
Smoker
96 2500 4x4 nv4500 3:54 slt 3"body lift 2. 5" suspension by skyjacker 267/75/16 street tires 36/12. 5/16 swampers for mud silencer ring lost 5" pipe borla KN round style filter JRE stage 4 400hp JRE afc spring kit boost and pyro gauges 16 housing pump timed and 3000rpm limit now 4200
Tom
Smoker
