Just did my first FF change... Not too bad of a job. . Did it from below. . Used A 1/2" drive with a universal joint and extension . .
From below. Drain canister. Unscrew the white drain tap til it drops. . I put a bucket under the diff and it drained right into it... . Then tighten the drain... unhook WIF sensor . . Use 1/2" drive wrench to loosen canister. It will drip down a little on the side. . when it is all the way loose, open the tap drain again to drain the rest out of the canister. . Then move the canister over by the firewall. . It comes down between the firewall and fuel lines. .
Filter pulls out easily. . slide new one in. . make sure it seats fully... Put on new O-ring. Lube with oil and screw canister back on going up by the firewall as before. . Not too bad. . Little messy but not bad.
