Got in some parts yesterday, and today I started putting them on.
Today was my first fuel filter change, and as always I figured out that to be a decent mechanic you need to have long, super articulated arms that bend in any direction to fish out the parts you need to remove and replace.
I stuck my big oil drain pan under the truck and let loose with the yellow lever, and the filter canister emptied itself onto the drain pan with hardly any muss or fuss.
Fuel filter came off reasonably easy, after removing the water warning wires and loosening up the 14mm nut. Fuel filter canister came out from underneath. I saw no way to pull it out through the top.
Inside the canister was a black film, along with some pea sized clumps of tarry looking stuff. The filter itself was black. I wonder how long it takes a fuel filter to go black?
Lubed up all the parts and put it back together. I didn't have any fresh clean diesel to fill up the canister and so I just put back together dry. Then I pumped away at that rubber bulb underneath hoping I could fill it up that way. Didn't work. So I just ran the starter a couple times, then loosened up the bleed screw and pumped that rubber bulb a few more times and fresh diesel came out and no air bubbles. Figured I was good to go. Turned the key and the truck started right up, happy as can be.
Replaced the intake horn gasket while I was at it. Then checked to see if the AFC housing was slid all the way forward. It wasn't quite. So I backed off on the starwheel to stock position, slid the AFC housing forward, and then tightened everything down, and turned the star wheel to the engine about 60 clicks until it was almost as far as it would go. Started the truck up and ran it up a few hills and it still doesn't seem to have all that much power that I was expecting from the #10 plate.
Turn off overdrive and ease my foot forward, it gets moving and shifts to second, and is still poking along at 2200 rpms, then shifts to 3rd and it feels like it suddenly has some torque. Doesn't feel like what I expected though.
Going to try and get the gauges installed tomorrow, though I kind of doubt I'll have enough time. Perhaps I can do the EGT.
Noticed today that the injector closest to the firewall is dirty and greasy. The others are clean as a whistle. Hope that this is due to just a bad washer.
GulDam
GulDam
