First Gauge Is In
Towing with an auto... .
Exhaust Brake FOR sALE
I got my first gauge (tach) installed today. I went with the Isspro 2" and the Isspro Dodge harness. Connected right up to the factory connector under the dash and took about an hour for everything. Works great! This is a great way to go for anyone wishing to add a tach.
Pyro and boost are next...
Ken
Tach
What was the part number for the tach and the dodge harness. I really like the idea of just plugging it in. That would sure simplify things.
How many greenbacks?
Thanks
CR Toney
See what you've started!
WOW! That's a good looking tach! Now you got me wanting one but I'm not sure where to mount it. Any pics or suggestions?
I don't have any pic's as of yet but will soon. I mounted it on the steering column. You can offset to the left or right and not block any factory instrumentation. Or where I have it now is in the center slid back into the hole in front of the speedo. It blocks the trip meter but that is all - you can still see the speedo needle on it's full sweep from O to 100. You could also mount it on the top of the dash or in a pillar pod if you wanted.
If you do go for the colum mount you will need to order the mounting cup for another $17. Be forwarned thought that the zip ties that come with it are to short to reach around the column. Fortunately longer zip ties are easy to come by.
Ken
