wheels
You can use the 94 wheels on the first gen trucks. . The main difference is that the 94 has no coin. It is just flat around the lug holes. If your truck is dual wheel you must use pairs of the aftermarket wheels together... . In other words... ... Do not use one stock wheel against one aftermarket wheel !!!!
Things you need to check on the aftermarket wheel before you buy.
1) the stud holes will need to be 5/8 ths. for 1 tons or 1/2" for 3/4 on
2) be sure that there is a large enough flat area around the lug hole for your
stock lug nuts to tighten down onto for 1 ton. . you will need new larger od lug nuts for 3/4 ton
3) be sure that your studs are going to be long enough to go threw the wheels
4) If the wheel you want uses cone/tapered lugs and your truck uses coin nuts
you will need to get new nuts. . Tell the parts counter man that you need nuts for an early 1970's 3/4 or 1 ton single wheel truck. The nuts are 5/8's 18 threads per inch with a 45 degree taper. Chevy used the lugs also but they had a 60 degree taper.
Kelsey Hayes still makes a special steel wheel for dual wheel trucks that will take the 235 x 85-16" tire... . (The stock wheels will only take up to 215)
If you need new wheels I would buy them and put stainless liners on them to make them look good...
I posted some tech info on hubs and wheels in the past... Take a look at those posts for more .
If you have any more questions on wheels and hubs PM me or send me your # and I will call you... .
mrpbody said:
I went to the local tire shop today to check on a set of new wheels for my 93-2x4 Dually, and was amazed when they told me that they don’t make them. They explained to me the wheels are “coined” (meaning the wheels center on themselves not the center hub of the brake drum) and are different than the newer 1994 and up models. I guess what gets me is that Dodge made abazillion of these trucks over the years and (nobody) makes wheels for them.
Does anybody know where to find wheels that will fit these years that will not cost an arm and a leg or somebody that makes adapters for the center hubs?
marty
