In this truck the fuel pin that rides the cone is stuck and we were trying to get it out. I looked on here and found someone said that if you turned in the fuel screw all the way that the pin might be driven out by higher pressure from what I understood. We also tried to get the pin out by going if what looked like a passage way from the back of the pin which was on the outside of the afc housing. We had to take off the throttle lever and unhook the linkage. Our problem now is that the truck wont idle even after we adjusted the idle up, it would run when I keep my foot on the pedal a little bit. Could something at the throttle have moved and are there any tips on making this run right again I havent tried.
Thanks
Thanks
