Re: Now you've done it
Originally posted by Matt S
Hey, now you let the cat out of the bag.
I'm starting to question a lot of things lately about these trucks. Was told that a 12cm2 would be too hot. It wasn't. Was told that the Power Wagon injectors would add power to my truck. They didn't. I think I may be looking into injectors again.
There are still some confusing things going on out there.
Your truck, with the early head, has very "open" injectors. Feel free to just crank up the pump, as the difference between the pump settings on your truck and on, say, a 92 or 93 is considerable. And you are correct, the PW injectors about match your stock injectors, possibly losing a small amount.
Just post them up for sale in the classifieds and try the Lucas injectors, which will do some for you... about 15-20 HP - OR, just crank the fuel up a bit.
The non-intercooled trucks have pumps with rather low fuel settings, but the same horsepower as later. The difference is, that the injectors have much larger holes than the later ones do. However, the particular injector you have as stock is slowly going obsolete. It has a 9MM tip size, and everything is now going to 7MM, with the newer heads. Cummins has a "replacement" injector for the early engines, but someone told me that the new number injectors Cummins sells lose power. I have no definitive proof of that, however.
As for figuring out if you have the 12CM housing... it's pretty easy... the ability to get rubber off the line is a good clue
