Competition First hooks on new Driveline/Tcase/Charger, DHRA Missouri pull and WI pull
Competition legal pullin hitch
Competition Scheid / Corsa / ItelliDash
The Missouri pull was my first hook with the new 271 Tcase and new drive shafts.
I had a 1 piece 4. 095" x . 180 wall rear shaft made along with a 3. 5" x . 083 front shaft, 1. 562 stub, using the stock CV.
This shaft setup has been tested to 110MPH in 2WD and works great!
While these were being installed, I also bolted on a Pro-Street 66 charger from High Tech. So far I'm very happy with this trubo, it is very streetable and spools better than my SP66.
Also, I had my converter loosened up a bit when I went to Goerends to have my billet shaft and hub replaced.
-Click here to see Video
Missouri DHRA pull, 268 feet. Did not lock the converter, ran 2nd gear unlocked at 3500RPM.
Washington County Fair Pull, 308 feet.
This was a 4th place hook. I was unable to get the turbo lit as it was 100 degrees. I ran 2nd gear locked up, worked very well!
I would have been at 3rd place, but the 1st place winner was a Duramax running nitrous (drugs were not allowed, but also weren't checked for) by the time they actually checked his truck, it was about 45 minutes after he pulled, and the nitrous was convienently disconnected.
He pulled 341 feet! 2nd place was 316 feet, a Duramax as well.
Looks like I have some more tuning to do!
