I've had my truck working now for a full month and have driven a little over 9300 miles, all but maybe 300 of them towing. I have some likes and dislikes and will list them below.
The Aisin transmission- The two extra gears make all the difference, I had a 95 auto and with 4 gears it never seemed to be in the right gear even after I put a full DTT transmission in it. This one is a lot better, although sometimes you might want to be in a different gear, this is about as close to a stick as far as being in the right gear as you are going to get with an auto.
The exhaust brake- If you tow, this should be an automatic purchase, (it should come standard with the towing package) In the tow/haul mode this thing will really shut you down.
The engine- At stock power with the Aisin transmission it will pull the maximum load I can pull (as far as the company alows) with no problems. That would be about 24,000, trailer and payload.
The ride- This all comes from the longer wheelbase (167") Compared to my 03 which had a 130" something wheelbase, this one is much better.
The interior- It is fine, nothing special, it doesn't have as many covyholes as the 03 did to put things, mainly in the sunvisor.
The 52 gal fuel tank- I won't have to put an auxiliary tank on which will leave me more space in my bed (11. 5 ft. flatbed)
Dislikes:
A couple of minor things and one major one that I have my dealer checking up on.
The oil filter is much more difficult to change than it was on my 03, the way I did it, but I will probably go to the Amsoil remote setup and not worry about it. It also looks like the fuel filter is going to be a little tougher to service than my 03 was also.
My major concern is the burn mode on the particulate filter. It has done it 6 times that I know of and every time it was the same. It will smoke like you have an injector hung open, blue-white smoke and a lot of it for about 15-20 seconds then it quits. I've had several truckers call me on the cb and tell me something must be wrong. It happened again yesterday on a back road and I stopped to see if I had a miss, (I didn't) the exhaust had a roaring sound in it and it was really hot so I know that is what it was. There is no indication of anything wrong on the instrument panel, the only way you would know it is happening is if you looked back and saw the smoke. It always seems to happen when I am pulling my trailer empty, never with a load. Like I said, I have my dealer checking on it. I'm not going to worry about it at this point, but I sure don't think it looks good for Dodge to have a new model truck going down the road smoking like crazy regardless of how short a time it is.
Other than that, to this point, I'm happy with the way the truck has performed.
Dislikes:
