I just received the report for an oil sample out of my 2006 3500. The report noted a concerning result: Silicates @ 30ppm (parts per million) This sample was of the OEM supplied oil from my first oil change @ 4,000 miles. The report speculated that the silicates are likely from dirt/dust contamination or bearing surfaces. ALthough 30ppm was not cause for immediate action the report did indicate it was cause for some concern. I'll be sending another sample from the second oil change. THe report also mentioned that since I didnt provide the Specs for the OEM oil (I didn't know what type/spec oil DC put in) it somewhat limited their analysis.
I am worried that there may be a problem with the OEM air filter subsystem.
