I just performed my first oil change on my 03 Ram Cummins with 3,700 miles on it and was pleasantly surprised. After reading all of the posts about having trouble getting off the original oil filter, I took the precaution and ordered from Geno’s Garage my filters and a 6 in 1 filter wrench. While I was ordering up those items, I ordered an EZ Change drain plug with the tube (no more mess). The filter came off pretty smoothly, even thought the 6 in 1 wrench slipped on it a few times. I didn’t even spill a drop of oil from the filter (not the norm for me with past vehicles). The new filter and drain plug went right where they belonged without a hitch. I like the Idea of the EZ Change plug but it obviously won’t let all of the oil out of the pan, so I will be spacing it with a washer or 2 to get it down a little lower in the pan so I can get the last few drops of oil out. I read some concern on another thread about the plug being damaged from impact while off roading. I don’t feel it sticks out far enough to be really concerned. I was also surprised to find only 2 Zerk fittings to grease (one at each end of the tie rods).
That same day I want over to the local auto parts store and noticed they had similar oil filter wrenches for less and Fram sells the same kind of quick drain plugs with hose for $15 instead of the ones in Geno’s for $48, but they didn’t have the 18 x 1. 5 plug size. Oh well.
I was also concerned after reading about problems on other threads of low fluid levels in the rear differential. So, I figured while I was at it, I’d check the fluid levels in both differentials. The front was fine but the rear required about a pint. There was also a considerable amount of steel dust/shavings on the magnetic plug. It makes me mad because when I bought the truck, I distinctly recall the salesman telling me to wait while they “check the diff and other fluid levels”, seems odd that they would mention the diff in particular. He must have known about the problem others were having, but obviously the tech didn’t, otherwise it would have been full. They also over filled the engine oil a quart, and they claim they have a 5 star ratting. :-laf
