Cummins tells you not to use Synthetic till after the "break in" period.
Back with my 99, that was for the first 20,000 miles.
The engines are machined so that you can run them hard out of the gate.
But since they are so finely machined, it takes longer for a true break in.
Part of that is for the rings to seat. If your not running it hard, and using synthetic the ring maynot seat and cause some blow by and oil consumption.
Dont run synthetic till after the suggested break in period. I don't know if it's any different on the new engines.
Stick with regular oil for now. The "break in" period should be somewhere in your manual. It's been ages for me, but that's where I thought I found it as well as the comment that the engines should be worked right out of the gate and not babied.
Get the Geno's kit 4/2/1 kit, great savings and all the right parts.
Also can check Cummins' site, I think there were some good FAQ's there about this, back when my truck was new.
