Well, last night I finally backed the truck into the garage last night and changed the oil. Yesterday was perfect day since we've been having 90+ heat and was maybe in the high 70's. Anyway, I used the good old strap wrench with a 10" extension, did a few tugs and such, broke lose fairly well. I think the giant man they use to put oil filters on was either sick or on vacation when my truck was on the assembly line. After getting the oil filter loose, I took the oil plug out (wanted to see how tight that oil filter was first) and drained into my new oil pan catcher... thought for a bit that it was going to overflow (has a solid top on it with a drain hole in the middle)... but it didn't. After it drained for about 5-10 minutes, I put on the new oil filter (forgetting to put new oil into it:{ ), put it on hand tight, figured that I've always changed filters on tractors & cars like that before and never seen it leak. Put in the Geno's flip drain plug (I'm going to look forward to the next change), put in 11 quarts and started it up... no problem... no leaks or anything. Got the mower out and mowed the lawn, once I was done, I checked the level and it was just fine. Summary: Definetly get a bag for that filter... tried a hamburger bun bag, but too thin and broke open on a bolt.
While I was under there, I looked for zerks to grease, but didn't see any. I also looked for what could be knocking going over bumps, but didn't see anything, but didn't spend a lot of time doing it. Anyone know what/if zerks to greese on this beast? Also, where in Omaha could I get some Anti-Freeze? I'm hoping some locals will help out here.
Got my new TDR issue last night, got me thinking again about gauges & exhaust brake... hmmm... Remote Control Jet or Exhaust brake???
