Well it wasn't easy but I did it with a little help of a friend. Drain plug came loose no problem but filter was a b***h. After ruining a strap wrench and putting a hole in filter a friend of mine came over with an oil filter wrench that clamps on the bottom of the filter and grips tighter as you turn it. It took all he had to break it loose. When I heard the rubber gasket squeaking I knew I finally had it off. 1 stratopore &11 quarts of rosmella later I was back on the road. Hope the next change goes easier!!
My arns are sore
