Hello All,
As stated in the title, this is my first post on the TDR. I have been following the threads for years, and finally joined within the last year. This site is an amazing resource.
My question concerns the factory oil pressure guage, I understand that it is controlled via ECM input and not by an actual sending unit and is based off of a 6 PSI switch. That aside, last night I changed my oil (5K interval) with the Mopar Oil Filter and 12 QT 15W-40 Mopar Oil. Well, upon restart and an easy drive to reach operating temps, I decided to "get on it. " After my smoke screen, my factory oil pressure guage reads lower than ever--at idle the needle sits right at the lower green mark of the "safe zone. " I have owned the truck since new and now have 25K on it. Previously, the needle never reached the lower green mark at idle--regardless of the temp (both outside environment and coolant). I am wondering if I need to visit the dealer? There are no leaks, and the dipstick reads FULL. If the gauge does not sense actual pressure, then what would cause a change in the "programmed sweep" of the needle?
I read on another post about a Bypass valve in the oil filter/oil filter housing? If this valve exists, is it possible that during my hard acceleration that the oil pressure spiked and caused the valve to stick--possibly open?
Thanks in advance for your input.
