Well, after a few months of getting the head off and cleaned up with valve job, new seals, shaved . 010, and then back on with . 020 marine gasket. Had a unmolested pump and changed out to a #10 plate, 4K GSK, and 370's, I went on its first test run.
I was having problems with it "popping" at around 1500-2000 rpms when I put it to the floor in neutral, I checked the timing... . had slipped to 11*, bumped it up to 18*, but slipped back to 16. 5* when tightened. Good enough for me, so I readjusted the govener (sp) to . 046 an the other to . 050. Fired her back up and idled much much better from 450rpms to 750rpms after. Fixed a fuel leak or two, cleaned out the fuel bowl thats between the started and motor mount on the drivers side. Wasn't bad at all. Still had some popping after that at high rpms. Could rev it up to 2500 real easy, but after holding it there after a second and then flooring it in neutral, would pop some more and rev up slowly from there.
I also got the guages wired up to so I can see whats happening.
Decided to take it down the road finally. After a second gear start and floored it the boost went to 32# went to third and only went to 22#. Drove it through a few more hard shifts and the boost only went to 22#. The pyro never hit 1000*+ expect for the first time I took off and went to 32# it hit 1200* pre-turbo.
After 2400 rpms or so it would climb slowly, but would rev quick before then. Never could hit 80mph with it to the floor.
I hope someone can tell me where to check first. I hope I gave enough data for someone to help me with this scenerio. I don't have a fuel pressure guage, so I don't know where I was on fuel pressure during the test run.
Can someone give me a place to start checking?
I guess I need to check the fuel pressure?
Check the timing again to see if it slipped?
Check govenor springs again?
Anything else?
HELP,
JD
P. S. Also after the test run the truck idled at 450rpms and before the test run it wa at like 750rpms.
Anything else?
HELP,
JD
