Stay away from the orange Dex-cool. Go with the Fleetguard extended or Delo EC-1. I took off the heater hose at the head (be sure to turn the heater on before you shut down the engine to open the heater core to flush) and flushed the heater core. There is NO block drain on the engine( why I don't know) so you have to remove the bottom hose from the radiator and drain out the coolant. Flush the block well and if you have an air compressor, you can GENTLY blow out the heater core and full force blow most of the water out of the engine. Because there will be some residual water left in the cooling system, If you can, get the concentrate, add 3 gallons of it first and then top it off with bottled water. Don't use water from a salt type water softener. It has residual salt left in it. I put a 180 thermostat in mine at this time.
