Hello all. I had my first opportunity to tow with a Cummins pickup this last weekend.
It also was the first time I pulled anything utilizing a pickup with a manual transmission.
At the ripe young age of 37 I pulled the trigger & bought a 82 c30 Chevy with the 6bt/nv4500 this past fall & finally learned how to drive a standard transmission.
Anyways... that truck is parked for the winter but I also bought a 97 Ram 2500 Ram seven weeks ago with the same setup plus 4 wheel drive.
It was definitely interesting being in control of the gears towing... I really enjoyed it except for the one stretch in town during relatively heavy traffic. That portion felt like a lot of work going stop light to stop light.
I didn't really take a lot of time researching it before going for it but I knew a few basics....I would love any advice/tips before I tow again.
I was pulling a Ditch Witch RT45 trencher (5500 lbs) & a 24' trailer that clocked in at almost 3000 lbs... I love good trailer brakes!
I believe the truck to be in stock form or very close performance wise. (For now)
I have previously towed with an old 6.2 diesel pickup as well as a 3/4 ton chevy w/ a built 454 & a late 90s chevy with Vortec 454... this was a much more enjoyable tugging affair.
In all fairness the big blocks were pulling more weight most of the time but I've never been able maintain speed going up hill.
I utilized first gear on most stops which I never do around town normally.
I didn't use 5th gear when towing... (seems like I read that somewhere)
It felt comfortable going 60mph +/- which was all that I was after anyways...you gotta stop at some point.
RPMs never got above 2400 in 4th gear & that was laying into it some going uphill. (354/355s I gotta look that up now)
I'd like some aftermarket guages...obviously boost & egt.
I'm thinking maybe transmission temp, oil, temp, & maybe fuel pressure??
I know that a few of those are redundant with the factory gauges but they are 22 years/230k miles old.
Being a regular cab 2500 I don't think that this will ever be my big hoss super pull truck that I daydream of. The big dually Crew Cab Chevy with a Cummins may be a better choice with a longer/wider base.
Additionally what would be some good mods to make?
Air filter or leave the stock setup?
I saw that Geno's has a deal that bolts onto the nv4500 for added capacity & cooling effect.
I am definitely going to make sure everything is in great mechanical shape & I have guages before I even go down the road of turning the fuel up any.
Sorry for the long post... just wanted to share & get some good towing tips to make every futire trip successful.
