First x-c flight today; doh!
First cars? (siblings)
Do you know who you Voted for??
Hello all
Did my first cross country flight today, took my youngest stepkid with us. You would think that your first landing at a different airport is just like your hundreth landing at home field, but for me it was not quite the same. Also first time in other than class E/G airspace, flew into class D. I seem to go partially braindead once in the plane, even if on the ground I can answer whatever is asked, guess that is why you need lessons:rolleyes:
Wish the plane would get off the ground like it had a Cummins, instead of only 150 hp. RPM is perfect, 2500 or so. Found out today that, with a warm day and more weight, density altitude matters. All of a sudden the calculations you never worried about before, make a difference!
Would trade the Cummins for a nice plane in a hearbeat:eek:
Doesnt take much power to get to the airport!
Eric
Eric
I used to dabble in the experimental stuff.
They make diesels for aricraft use, why trade... . have both. :D
Eric
I read about one of the major aircraft engine manufacturers designing a diesel aircraft engine.
Ups and downs is right, first time through a canyon, most wind which means some constant turbulence, at least off the peaks in a canyon, and highest density altitude with most weight, but that is how you learn. Learn by doing. Did ok, needed to pay more attention to where I was by the flight plan, and still fly the plane.
3 plus fuel, on a warm day, was lots different than only 2 in cool weather! Plane is a PA28/151 Cherokee Warrior.
Nothing like it! Oo.
I havent jumped yet though, so that doesnt count. Soon!
I would hate that too, but better an engine than a surface!
Hello all
Eric
Congratulations!!!
I remember my first cross country... flew from Evansville, IN to Cape Girardeau, MO, and back. That was in 1989 in a 1962 C-172 with a Continental engine. It was old, loud, had a bazillion hours on it, the fuel gauge for the right tank didn't work, the passenger door was tied shut, and the seat wouldn't scoot forward (so I used a flotation cushion behind my back). It was hot in it because I was too nervous to open the vents, and it was raining between the airports so hard I could only see straight down.
I had a blast and it's still one of my favorite flights. N5969R was it's tail number.
On my second cross-country, a three-legged journey, I took off from a grass strip in a C-150 and hit a rabbit. I heard the loud "THUMP", but it was just as I was rotating the nose up. So, I radio'ed back to a friend who was going to take off behind me and he said he saw the varmint... I did a low pass over the field and was told that I had a flat front tire. Talk about pucker factor... I circled back around and carried the nose gear in the air as long as I could after touching back down. Got the tire fixed, but the shock absorbing strut was busted and leaking. I flew it anyway and it was fixed not long after I finished the cross-country. I practiced my "soft-field" take-offs and landings on that one!
Duane
01 Ram 4x4 "Brandy"
