When I had my truck at the dealer to fix my hard start problem I requested they replace the transmission fittings mentioned in the TDR[dealer subscribes]. Ser advr said there was no p/n for the item besides I had a 95 which doesn't use the plastic fittings. So off to Sask. Canada 3500 mi round trip. In Auburn, Ca. about 120 mi, coming home, the back of the truck was clean as a whistle. In Roseville 85 mi. to go, the back was covered with nasty red oil. Trouble shooting revealed the tran. line fitting at the water to oil cooler had failed wherein I lost three qts of oil. That coffee stop save me a new transmission. To replace the line and fitting dealer quoted 350. 00. Upon further investigation of the failure mode noticed a 'U' shaped clip held the line in the fitting. The clip was missing, by using good ole plow wire and back pocket pliers replaced missing clip. I later found a piece of the clip on the frame which showed evidence of vibration wear through. Hope I get 90k on the wire like the OEM. A check of the clip can be made by pulling down on the loop. If it bends replace it. Save yourself a lot of money.
95 ext cab 3500 shaker Whitney boost gage air springs/Amerigo camper.
