HEMI®Dart
I read in a post awhile back that Mikepvg (Thanks Mike) changed the quad O-ring that's above the fuel heater element and that cleaned up the blue smoke at start-up. I couldn't see how this would effect it at all. First if the o-ring was bad, you'd probably leak fuel and/or suck air into the fuel system. I figured I would change it anyway. It's a simple and cheap fix.
After changing the O-ring, any hint of blue smoke at start-up is gone. Nothing. No smoke of any color. I still can't believe it.
The OEM O-ring looked in good shape. A little worn, but didn't appear not to be sealing.
The O-ring is Fleetguard Part # 383418500 S. About . 30 cents.
Directions:
1. ) Remove fuel strainer
2. ) Get an 8mm or 5/16" allen wrench. I used a 1/4" drive allen head socket. The bolt to drop the heating element is recessed up into the heater. You'll need to use the long end of the wrench. This didn't work. Its pretty tight. A 3/8" drive 8mm allen socket is too wide to fit up into the hole to get to the bolt.
3. ) unsrcrew heating element bolt, drop element, remove old O-ring. Place new O-ring into the groove, and carefully raise it up back into position. Make sure the electrical connector is seated back into its slot in the housing. I did 99% of the work from under the truck.
You want to drop the black piece above the strainer bowl & screen and replace the upper O-ring that seals it to the housing. See below:
From Fritz's web Page:
Posted to the TDR Forum by Mikepvg: While the strainer assembly is removed, check the Fuel Heater Element quad O-ring gasket on top of the heater element for signs of deterioration. After you remove the pre-filter bowl, you have access to the allen screw that will allow the heater element to be removed. NOTE: This screw appears in the service manual diagrams, but no mention of it is made in the instructions. All can be accessed from top of engine compartment. The pre-filter screen kit has the quad ring for the BOTTOM of the heater element & is a different size than the top one. One member posted that replacing replaced BOTH quad rings reduced the amt of blue smoke on start up & WOT substantially. The PN is Fleetguard 3834185-S & cost only . 66 cents from Cummins
Directions:
