I've been chasing a loss of prime issue for the last 3 days now.
It all started with the fuel line steel inlet fittings on the top of the tank leaking,,I had a 2003 module from which we took the plastic inlet fitting unit and spliced it to the 96 inside module supply and return line,,took the module appart and cleaned up the filter screens,,,tested the inlet pipes to be sure our splice did not leak air and tested ok,,
While i was there,,changed the fuel lines from tank to pump,using a combination of braided line and a straight section of 5/16 and 3/8 steel fuel line. .
After all this work,,truck wouldn't start,,,would not prime at all,,so we pressurized the tank with a bit of air pressure,,,that got it somewhat primed and after some injector bleeding it started up,,but after letting it sit for 20 minutes it lost prime and would not start at all. ,
The filter was also replaced.
The next test i hooked up a small 12v motocycle fuel pump fed from a outside fuel container with both supply and return into it,,,and that would keep it running even when reved up... . then we disconnected the mootorcycle pump and just stuck the lines in the fuel container and reved up the mootor pretty good,,,a minute later the truck was dying almost stalled,,i kept a light foot on the throttle and it seemed to let the fuel supply catch up,,,but if i reved it up more it tries to stall...
This is making rip my hair outta my head,,which are hard to replace at my age,,
If anyone has any input i would GREATLY,,GREATLY,,appreciate it,,,
Thanks all. .
Thanks all. .
